Automatically Enabling the Remote Scanner Function
You can set to automatically enable the remote scanner function when you press [Scanner] on the Main Menu screen.
This mode can be set when the Scan function is available for use. For information on the optional products required to use the Scan function, see
"Optional Products Required for Each Function."
Press
![](./images/book_images/b_in_Add.jpg)
(Settings/Registration).
Press [Function Settings] → [Common] → [Scan Settings].
Press [Auto Online].
4.
Press [On] → [OK].
Select [Off] if you do not want to automatically make the machine go offline.
If the remote scanner function is enabled, scanning is not possible with [Copy] or [Scan and Store].
