Adjusting the Paper Folding Position
You can adjust the folding positions of the paper when a folding mode is set.
The saddle fold positions can be adjusted when the Booklet Finisher-P1 is attached. (See "Staple Finisher-P1/Booklet Finisher-P1/External 2 Hole Puncher-A1/External 2/4 Hole Puncher-A1/External 4 Hole Puncher-A1.")
The C-fold or Z-fold can be adjusted when the Document Insertion/Folding Unit-H1 is attached.
(See "Document Insertion/Folding Unit-H1/Document Insertion Unit-L1.")
Press
(Settings/Registration).
Press [Adjustment/Maintenance] → [Adjust Action] → [Adjust Fold Position].
Select the method for the folding position of paper.
To adjust the position of the Saddle Folding, select the paper size you want to change.
4.
Adjust the folding position by pressing [
] or [
] → press [OK].
If you selected [Adjust C-Fold Position], adjust the two folding positions (A and B).
