You can set the machine to display the Fax function on the Main Menu screen. If you want the fax function to be displayed on the Main Menu screen, you can select whether or not to display the fax function in [Scan and Send]. By displaying the fax function in [Scan and Send], you can send to various destinations using different sending methods, such as e-mail and I-fax, at the same time.
For information on the optional products required to use this function, see
"Optional Products Required for Each Function."
Press
![](./images/book_images/b_in_Add.jpg)
(Settings/Registration).
Press [Preferences] → [Display Settings] → [Display Fax Function].
Press [On] → [OK].
Press [Off] if you do not want to display the Fax function on the Main Menu screen.
If you set <Enable Fax in Scan and Send Function> to 'On', the Fax function appears in [Scan and Send].
This mode is enabled only after you restart the machine. For instructions on restarting the machine (turning the main power switch OFF, and then ON), see "How to Turn ON the Main Power."
