Changing and Canceling Copy Settings
You can use the Setting Confirmation screen to confirm, change, or cancel selected copy modes.
Press [Copy].
Set the desired copy modes → press [Check Settings].
You can check the settings.
A right triangle () displayed on the [Change] button when a copy mode is selected indicates that more setting screens are available by pressing the key.
Change the selected copy mode → press [Change].
Changing the copy mode:
Canceling the copy mode:
Change the settings → press [OK].
Change the settings as required, using the same procedure as for setting each mode.
Press [Cancel Settings].
To cancel a mode that does not have a setting screen, press [Change].
4.
Press [OK].
» Copy » Changing and Canceling Copy Settings
08KY-0KY
