[Each Session]:
Checks the date and time information every time the machine starts up, and downloads from the server if the contents have been updated, or from the cache if the contents have not been updated.
[Each Access]:
Checks the date and time information every time the Web page is accessed, and downloads from the server if the contents have been updated, or from the cache if the contents have not been updated.
[Cache Priority]:
Does not check the date and time information, and downloads the contents from the server if the cache is not saved, or from the cache if they have been saved in the cache.
It may take several minutes for the cache to clear, depending on the amount of data saved in the cache.
If you do not want to delete the cache, press [No].
The default setting for [Use Cache] is 'Off'.
