08KY-14H
You can check a folder's detailed information, create a new folder, and delete a folder in the Advanced Box.
Checking the Detailed Information for a Folder
Press [Access Stored Files] → [Advanced Box].
Select the desired storage space → select the desired folder level → press [Folder Operations].
Select the desired folder → press [Details] → [OK].
If you want to change the folder name, press [Rename Folder].
4.
Press [OK].
Press [Create Folder].
4.
Enter a name for the folder → press [OK].
5.
Press [OK].
Select the desired folder → press [Delete].
4.
Press [Yes].
