Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Storing New Addresses » Storing/Editing/Deleting One-Touch Buttons
08KY-101
You cannot register new destinations in a group destination that is stored in a one-touch button. The destinations must be registered in the one-touch buttons beforehand.
Storing/Editing One-Touch Buttons
Press [Scan and Send] → [One-Touch].
Press [Register]→ select a one-touch button to store or change → press [Register/Edit].
If you know the three digit number for the one-touch button, you can press → enter the three digit number of the desired one-touch button using - (numeric keys).
If you select a one-touch button in which a destination is already stored, proceed to step 3.
The following icons are displayed to indicate the stored destination type for one-touch buttons in which a destination is already stored:
(E-Mail)
(Fax)
(I-Fax)
(File server)
(Group)
Select the type of destination to register.
For instructions on registering a fax number in a one-touch button, see "Storing New Addresses."
If you select [E-Mail]:
If you select [I-Fax]:
If you select [File]:
If you select [Group]:
If you select [LDAP Server]:
Press [E-Mail].
Enter a name for the address [Name] in accordance with steps 5 and 6 of "Registering an E-Mail Address."
Press [One-Touch Name].
Enter a name → press [OK].
Press [E-Mail Address].
Enter the e-mail address → press [OK].
Select one of the following for <Divide Data> as necessary → press [OK].
For details on Divide Data, see step 4 of "Specifying a Destination by Entering an E-mail Address."
Press [I-Fax].
Enter a name for the address [Name] in accordance with steps 5 and 6 of "Registering an I-Fax Address."
Specify the I-fax address in accordance with steps 8 to 14 of "Registering an I-Fax Address."
Press [File].
Enter a name for the address [Name] in accordance with steps 5 and 6 of "Registering a File Server Address."
Specify the file server address in accordance with steps 8 to 17 of "Registering a File Server Address."
Press [Group].
Enter a name for the address [Name] in accordance with steps 5 and 6 of "Registering a Group Address."
Press [Add from One-Touch] → select a destination to store in the group address → press [OK].
You can only select destinations that are already stored in one-touch buttons to be part of a one-touch button group address.
If you know the three digit number for the desired one-touch button, you can press → enter the three digit number of the desired one-touch button using - (numeric keys).
If you want to also store the data to be sent in a mail box, press [Store in Mail Box] → select the desired mail box → press [OK].
You can register only one mail box in a group address.
Press [OK].
Press [LDAP Server].
Specify the address by using LDAP server in accordance with steps 4 to 9 of "Specifying Destinations Using the Address Book (LDAP Server)."
Select the destination from the search results → press [Next].
You cannot select multiple destinations at the same time.
To cancel a specified destination, select the destination you want to register again.
The information that can be obtained via the LDAP server consists of only names, e-mail addresses, and fax numbers.
Press [OK].
4.
Press [Close] → [OK].
Press [Register] → select the one-touch button to delete → press [Delete].
(E-Mail)
(Fax)
(I-Fax)
(File server)
(Group)
Press [Yes].
4.
If you set [Language/Keyboard Switch On/Off] to 'On', the host name and folder path of the file server destination may not appear correctly, and you may not be able to browse them. (See "Enabling the Language/Keyboard Switch.")
Destinations stored in one-touch buttons also appear in the Local Address Book.
For instructions on registering/editing a fax number, see "Storing New Addresses."
