You can set [Use integrated authentication] in the following cases:
If you manage users by login service, such as SSO-H
If the login name and password for accessing the machine are the same as those that registered in [User Access Control for Advanced Box]
If you access to the Advanced Box using the touch panel display
This setting is invalid if you access to the Advanced Box from the Remote UI.
You can also log in by entering the URL of [User Access Control for Advanced Box] in the address bar, as indicated below. (Case sensitive.)
http://<IP address or host name of the machine>:8000/uactrl/
