Loading Pre-Punched Paper
You can load pre-punched paper to the following paper source:
Paper Drawers of the main unit
Multi-purpose Tray
Paper Deck Unit-A1
Paper Deck Unit-D1
When loading pre-punched paper, take note of the orientation of the binding holes and the image.
When pre-punched paper is loaded in the paper drawer of the main unit, the side facing down is the one printed on.
When pre-punched paper is loaded in the Multi-purpose Tray, Paper Deck Unit-A1, or Paper Deck Unit-D1, the side facing up is the one printed on.
If you are making one-sided prints, select [Face Up (Reverse Order)] in [Face Up/Face Down]. (See "Collating Copies.")
If you want to output prints with the printed face down, select plain paper with horizontal (landscape) orientation in [Select Paper]. (See "Paper Selection.")
» Maintenance » Loading Paper » Loading Pre-Punched Paper
08KY-0FW
