Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Specifying Destinations » Entering a New Fax Number
08KY-0S8
You can specify a fax number using - (numeric keys), , and . You can also specify several numbers in succession, and send the original to several destinations in a single operation (Sequential Broadcast).
Press [Fax].
Enter the recipient's fax number using - (numeric keys), , and .
For instructions on performing this operation from the Fax screen, see "Fax Basic Features Screen."
If [Set Details] is displayed:
If [Subaddress] is displayed:
Press [Set Details].
Press [Subaddress].
Enter the recipient's subaddress using  - (numeric keys), , and .
Press [Password].
Enter the password using - (numeric keys), , and .
If the recipient did not set a password for the target subaddress, you do not need to enter a password.
If you want to attach a subaddress to your send job, make sure that the recipient's fax machine supports ITU-T (International Telecommunication Union - Telecommunication Standardization Sector) standard subaddresses. (See "Sending with a Subaddress.")
Select the telephone line → press [OK].
For information on selecting the line to use, see "Selecting the Telephone Line When Sending a Fax."
Press [Subaddress].
Press [Password].
Press [OK].
Press [OK].
You cannot insert a pause at the beginning of a number.
If you enter a pause at the end of the number, the pause is always 10 seconds long.
