Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Canceling a Job
Canceling a Job
08KY-0S3
Canceling a Job That Is Scanning
Press [Cancel] on the screen that appears while the machine is scanning.
Press [Yes].
You can cancel a send job by pressing (Stop), while the job is being scanned.
Canceling a Job Being Sent or Waiting to Be Sent
Press (Status Monitor/Cancel).
Press [Send] → [Job Status].
Press the drop-down list → select [Fax].
4.
Select the job that you want to cancel → press [Cancel].
You cannot select multiple jobs and cancel them all at once. Select and cancel one job at a time.
5.
Press [Yes].
Check the destinations for the fax job → press [Current Jobs] or [All Jobs]. If you do not want to cancel any job of the Sequential Broadcast, press [Current Jobs].
The canceled job appears as <NG> (No Good) on the Log screen.
You can press (Stop) to cancel a send job that is currently being scanned.
