Category Top
What This Machine Can Do
The Touch Panel Display
Setting the Main Menu Screen
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Position and Angle of the Touch Panel Display (Upright Control Panel-B1)
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Entering the Department ID and PIN
Login Service
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Delivery)
Installing System Options/MEAP Applications (Manual)
Displaying the Installation Log
Performing a Communication Test With the Delivery Server
Updating Firmware
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
Forwarding Conditions List
Registered LDAP Server List
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
(Energy Saver) on the control panel. To reactivate the machine, press
(Energy Saver) again. |
The Energy Saver mode's energy conservation level can be set to '-10 %', '-25 %', '-50 %', or 'Zero Restore Time'. The default setting is '-10 %'. (See "Change Energy Saver Mode.")
(Energy Saver), or specify to have the machine enter the Sleep mode at a preset time. To reactivate the machine, press
(Energy Saver).|
Even if the main power switch is turned OFF, a small amount of energy is consumed if the power plug is left inserted into the power outlet. If you do not want any energy consumed, remove the power plug from the power outlet.
For more information on the mode which activates after
(Energy Saver) is pressed, see "Switching Modes Activated After Pressing Energy Saver Key."The touch panel display turns OFF when the machine enters the Sleep mode.
The machine can continue to receive I-fax or fax documents, and process or print data sent from computers even if it is in the Sleep mode.
The machine may not enter the Sleep mode completely depending on certain conditions. For more information, see "Energy Consumption in the Sleep Mode."
Press
(Energy Saver) to enter the Sleep mode when not using the machine for a prolonged period of time, for example, at night.The time it takes for the machine to automatically enter the Sleep mode can be set from 10 seconds to 4 hours. The default setting is '1' minutes. (See "Auto Sleep Time.")
If a Macintosh, which has been turned OFF, is connected to the machine via a USB cable, when you turn the machine ON, the Macintosh may also turn ON. In this case, disconnect the USB cable. You may also be able to solve this problem by using a USB hub between the machine and the computer.
The Auto Sleep Weekly Timer settings can be set from Sunday to Saturday and 00:00 to 23:59. (See "Auto Sleep Weekly Timer Settings.")
If you select [Low] for [Sleep Mode Energy Use], it may take approximately 10 seconds for the touch panel display to appear after pressing
(Energy Saver). (See "Energy Consumption in the Sleep Mode.") |
