If the machine is idle for a certain period of time (after the last print job or key operation is performed), the machine automatically enters the Energy Saver mode or Sleep mode to save power.
You can set which mode is activated after
![](./images/book_images/b_in_energy_saver.jpg)
(Energy Saver) is pressed.
(See "Switching Modes Activated After Pressing Energy Saver Key.")
Press
![](./images/book_images/b_in_Add.jpg)
(Settings/Registration).
Press [Preferences] → [Timer/Energy Settings] → [Auto Sleep Time].
Press
![](./images/book_images/b_in_tridown.jpg)
![](./images/book_images/b_in_triup.jpg)
to specify the desired Auto Sleep Time → press [OK].
The default setting is '1' minute.
It is recommended that you use the default setting for this item.
