Entering Characters from the Touch Panel Display
For screens that require alphanumeric entries, enter characters using the keys displayed on the touch panel display, as described below.
Entering Characters
Press the drop-down list → select the entry mode → enter characters.
The procedure for entering characters with each entry mode is as follows.
Entry Mode
Example
Procedure
Alphanum.
Canon
Enter 'Canon'.
Symbol
Press [%].
To enter uppercase letters, press [Shift].
To enter a space, press [Space].
To move the cursor, press or .
To switch the entry mode, press the entry mode drop-down list → select the entry mode → enter the desired characters or symbols.
If you make a mistake when entering characters, press or to position the cursor → press [Backspace] to delete the characters → enter the correct characters.
To delete all of the characters you have entered, press (Clear).
The available entry modes, and the maximum number of characters that you can enter vary, depending on the type of entries you are making.
If you often enter texts which consist of uppercase letters (e.g., AAAAA BBBBB CCCCC), select [On] for [Use Keyboard Shift Lock Feature] in [Preferences] (Settings/Registration). (See "Changing the Keyboard Shift Lock Feature Settings.")
If you often enter texts which begin with uppercase letters (e.g., Aaaaa Bbbbb Ccccc), select [Off] for [Use Keyboard Shift Lock Feature] in [Preferences] (Settings/Registration). (See "Changing the Keyboard Shift Lock Feature Settings.")
When you have entered all characters, press [OK].
When entering characters on the SSO-H authentication screen or in MEAP application functions, the screen you actually see may be different.
For information on displaying the keyboard, see the description for each function.
» Basic Operations » The Touch Panel Display » Entering Characters from the Touch Panel Display
08KY-017
