You can reserve printing while the machine is in the waiting state at the following times:
Between the time that the machine is turned On and when it is ready to print
After you clear a paper jam
Directly after you close a cover on the main unit or an optional unit, such as a finisher
You can select up to six files to be reserved.
If you select seven or more files to print at one time, the confirmation screen appears.
You cannot reserve a print job if the memory of the machine becomes full.
Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
You can register paper types that are not displayed on the detailed settings list in <Change Multi-Purpose Tray Paper: Paper Type>. For more information on storing the paper type, see "Registering/Editing Custom Paper Types."
If there is more than one reserved job waiting to print, only the last paper size/type specified for the reserved print job appear on the Paper Select screen.
If [Register Multi-Purpose Tray Defaults] is set to 'On' in [Preferences] (Settings/Registration), the stored default values appear. (See "Registering Multi-Purpose Tray Default Settings.")
[Transparency] can be selected only if you select [LTR] as the paper size.
If the envelope type is not set correctly, a paper jam will occur.
If you use envelopes that have glue attached to their flaps, the glue may melt due to the heat and pressure of the fixing unit.
Make sure to load the same paper size and type selected in step 5 into the multi-purpose tray. Printing does not start if paper of a different size or type is loaded.
You can specify up to six jobs to be reserved, including the current job. If you select seven or more files to print at one time, the confirmation screen appears. Interrupt print jobs are not included in this count.
You can set different print modes and paper sources, including the multi-purpose tray, for each reserved job.
If [Register Multi-Purpose Tray Defaults] is set to 'On', reserved printing can be performed only for the registered paper size and type. (See "Registering Multi-Purpose Tray Default Settings.")
For more information on paper types, see "Available Paper Stock."
