Memory RX Inbox
The Memory RX (Receive) Inbox is an inbox for storing files received by Fax and I-Fax. Files received by the Memory RX Inbox are stored without being printed. You can print or send the stored files whenever necessary.
If you want to use Memory Lock, you must first set [Use Fax Memory Lock] and [Use I-Fax Memory Lock] to 'On'. (See "Specifying the Fax/I-Fax Inbox Settings.")
You cannot store any more documents in inboxes in the following cases. (The numbers below may vary depending on the remaining capacity of the hard disk.)
When a total of 1,500 documents are stored in the Fax/I-Fax Inbox
When a total of 6,000 pages of documents or images have been stored in any or all of the Fax/I-Fax Inbox
If a message prompting you to enter the PIN appears, enter the number registered in [Memory RX Inbox PIN]. (See "Specifying the Fax/I-Fax Inbox Settings.")
» Fax/I-Fax Inbox » Memory RX Inbox » Memory RX Inbox
0JJC-11H
