Available Administrator Settings Table (Touch Panel Display)
If the administrator is specified, you can restrict operations by general users and allow the administrator to set the settings of each function on Settings/Registration. The settings available for operation vary according to the type of administrator. This section describes the settings in Settings/Registration that each type of administrator can operate.
Preferences
If the administrator is specified, the following settings in [Preferences] can be set only by the administrator.
: Only the administrator can change the settings.
-: Depending on the type of the administrator when using the SSO-H, settings cannot be changed.
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Paper Settings]
[Paper Type Management Settings]
[Display Settings]
[Default Screen after Startup/Restoration]
[Display Fax Function]
[Store Location Display Settings]
[ID/User Name Display On/Off]
[Display Remaining Toner Error Message]
[Delete Remaining Toner Error]
[Timer/Energy Settings]
[Date/Time Settings]
[Time Format]
[Quick Startup Settings for Main Power]
[Restrict Auto Reset Time]
[Network]
[Confirm Network Connection Set. Changes]
[TCP/IP Settings]
[IPv4 Settings]
[IPv6 Settings]
[DNS Settings]
[WINS Settings]
[LPD Print Settings]
[RAW Print Settings]
[SNTP Settings]
[FTP Print Settings]
[WSD Settings]
[Use FTP PASV Mode]
[IPP Print Settings]
[Multicast Discovery Settings]
[Use HTTP]
[SSL Settings]
[Proxy Settings]
[Confirm Dept. ID PIN]
[IPSec Settings]
[NetWare Settings]
[SNMP Settings]
[Dedicated Port Settings]
[Use Spool Function]
[Startup Settings]
[Ethernet Driver Settings]
[IEEE 802.1X Settings]
[Firewall Settings]
[IPv4 Address Filter]
[IPv6 Address Filter]
[MAC Address Filter]
[IP Address Block Log]
[External Interface]
[USB Settings]
Adjustment/Maintenance
If the administrator is specified, the following settings in [Adjustment/Maintenance] can be set only by the administrator.
[Adjust Image Quality]
[Dither Pattern Settings]
[Adjust Toner Volume Used for Color Printing]
Function Settings
If the administrator is specified, the following settings in [Function Settings] can be set only by the administrator.
[Common]
[Print Settings]
[Copy Set Numbering Option Settings]
[Secure Watermark/Document Scan Lock]*1*2
[Scan Settings]
[Auto Online]
[Auto Offline]
[Generate File]
[Rights Management Server Settings]
[Document Scan Lock Operational Settings]*2
[Set Authentication Method]
[Copy]
[Select Color Settings for Copy]
[Printer]
[Restrict Printer Jobs]
[PDL Selection (Plug-n-Play)]
[Send]
[Common Settings]
[TX Report]
[Report with TX Image]
[Confirm SSL Certificate for WebDAV TX]
[Limit New Destination]
[Always Add Device Signature to Send]
[Limit E-Mail to Send to Myself]
[Restrict File TX to Personal Folder]
[Personal Folder Specification Method]
[Restrict Resending from Log]
[E-Mail/I-Fax Settings]
[Communication Settings]
[Confirm SSL Certificate for SMTP TX]
[Confirm SSL Certificate for POP RX]
[Maximum Data Size for Sending]
[Default Subject]
[Specify Authentication User Dest. to Reply]
[Set Authentication User Destination to Sender]
[Allow Unregistered Users to Send E-Mail]
[Full Mode TX Timeout]
[Print MDN/DSN upon Receipt]
[Use Send via Server]
[Allow MDN Not via Server]
[Restrict TX Destination Domain]
[Autocomplete for Entering E-Mail Addresses]
[Fax Settings]
[Use Auth. User Name as Sender Name]
[Fax TX Report]
[Set Line]
[TX Start Speed]
[Confirm Entered Fax Number]
[Allow Fax Driver TX]
[Confirm Before Sending When Fax Dest. Incl.]
[Restrict Seq. Broadcast When Fax Dest. Incl.]
[Receive/Forward]
[Common Settings]
[Interrupt and Print RX Jobs]
[Handle Files with Forwarding Errors]
[Forwarding Settings]
[Set Fax/I-Fax Inbox]
[Memory RX Inbox PIN]
[Use Fax Memory Lock]
[Use I-Fax Memory Lock]
[Memory Lock Start Time]
[Memory Lock End Time]
[Divided Data RX Timeout]
[Always Send Notice for RX Errors]
[Fax Settings]
[RX Start Speed]
[RX Password]
[Store/Access Files]
[Network Settings]
[Protocol for External Reference]
[Confirm SSL Certificate for Network Access]
[Memory Media Settings]
[Secure Print]
[Simple Authentication Settings]
[Only Allow Encrypted Print Jobs]
*1 The setting names may differ depending on the optional products available for use.
*2 Indicates items that appear only when the appropriate optional equipment is available for use.
Destination Settings
[Address Book PIN]
[Manage Address Book Access Numbers]
[Include Pswd. When Exporting Address Book]
[Register LDAP Server]
[Auto Search When Using LDAP Server]
[Change Default LDAP Search Conditions]
[Register/Edit LDAP Search Conditions]
[Acquire Remote Address Book]
Management Settings
If the administrator is specified, the following settings in [Management Settings] can be set only by the administrator.
[User Management]
[System Manager Information Settings]
[Department ID Management]
[Device Management]
[Device Information Settings]
[Device Information Delivery Settings]
[Limited Functions Mode]
[Certificate Settings]
[Display Job Status Before Authentication]
[Display Log]
[Save Audit Log]
[Store Key Operation Log]
[Format Encryption Method to FIPS 140-2]
[License/Other]
[Register License]
[MEAP Settings]
[Remote UI]
[Delete Message Board Contents]
[Remote Operation Settings]
[Use ACCESS MANAGEMENT SYSTEM]
[Register/Update Software]
[Start Setup Guide]
[Data Management]
[Delete Existing Data Settings]
[Initialize All Data/Settings]
[TPM Settings]
For information on the types of administrators, see "Administrator Settings."
» Security » Available Administrator Settings Table (Touch Panel Display)
0JJC-1XH
