Loading Settings Information (Import Individually)
If you import an Address List (Delete and Overwrite) or Forwarding Settings, the information stored in [Favorite Settings] from the control panel of the machine and Recall memory are erased.
Loading an Address List
You can load an Address List into the machine from saved files.
Click [Settings/Registration] → select [Data Management] for <Management Settings>.
Click [Address Lists] for <Import/Export Individually> → [Import...].
If a PIN is set for the Address List, a dialog box prompting you to enter the PIN appears. Enter the Address List PIN → click [OK].
Specify the desired settings → click [Start Importing].
If you want to import an encrypted Address List file, select [Decode Address List Certified Information] → enter the correct password.
Details of each item are shown below.
Address List:
Select the Address List to be imported.
Import Method:
Select the import method for the Address List selected in <Address Lists>.
[Add]: The addresses in the file are added to the address list selected in <Address Lists>. No changes are made to the pre-existing addresses. Addresses in the file that have the same name as those already stored on the machine will be treated as new registrations with the same name.
[Delete and Overwrite]: All addresses stored in the Address List selected in <Address Lists> are deleted, and the contents of the file are loaded into the machine.
File Path:
Specify the location of the file to load.
File Format:
Select the format specified when the file was exported.
[Custom Format]: The dedicated file format for Canon machines.
[LDAP Format]: Select this if the file is to be used by another application (e.g., Microsoft Internet Explorer, Netscape Navigator, Microsoft Outlook, Eudora, etc.).
If you select [Address List One-Touch] for <Address Lists>, you cannot select [Add] for <Import Method>. Therefore, each one-touch button destination registered in the machine is overwritten when you perform the import procedure. You can also only import files exported with [Custom Format] selected.
You can register up to 1,800 addresses in an Address List. (200 of these are addresses assigned to the one-touch buttons.) Each address is treated as a separate item. When importing additional addresses, make sure that you do not exceed an overall total of 1,800 addresses.
When importing an LDAP format file, entries with e-mail addresses are imported into the machine. Make sure that the number of destinations to register does not exceed 1,800.
The name of the Address List is not imported.
Loading Device Settings
You can load device settings into the machine from saved files.
Click [Device Settings (Forwarding Settings, Address Book, Send Function Favorite Settings)] for <Import/Export Individually> → [Import...].
File Format:
Select the format of the file that is to be exported. The file format for exported device settings differs according to the model of your machine. Check the exported file.
[FIM Format (Forwarding Settings, Address Book and Send Function Favorite Settings)]:
The file extension is ".fim." Files saved in this format include the Address List, forwarding settings, and Favorite Settings. When you export the device settings of the machine, the file is saved in this format.
[FIA Format (Forwarding Settings and Address Book)]/[FIL Format (Forwarding Settings and Address Book)]:
The file extension is ".fia"/".fil." Files saved in this format include the Address List and forwarding settings. When you export the device settings of a different model machine, the file may be saved in this format.
File Path:
If you import the device settings, the Address List is also imported, causing the registered destinations to be deleted and overwritten with the destinations in the imported file.
The machine must be restarted to enable the imported device settings. After importing, turn Off the main power of the machine, and turn the main power back On again.
After importing device settings, the Remote UI cannot be used to perform other operations until the machine is restarted. Turn Off the main power of the machine, and turn the main power back On again.
If the data exported from this machine is imported by models other than imageRUNNER ADVANCE C350iF/C250iF, [Favorite Settings] on the control panel is not updated.
Do not import any files while the machine is executing other jobs.
For instructions on turning On/Off the machine, see "Main Power and Energy Saver Key."
Loading the Web Access Favorites
You can load a list of favorites registered in the web browser into the machine.
For more information, see "Importing Favorites from a Computer File."
When you import favorites from a computer file, the existing registered favorites in the machine are overwritten.
When you import a file, use the same file format as the data that was exported. Data in a different format cannot be imported.
The imported Web pages are displayed as icons on the Main Menu screen.
When 21 or more favorites are imported, only the first 20 pages in the list are imported.
Loading Printer Settings
You can load printer settings saved as a file into the machine.
Click [Printer Settings] for <Import/Export Individually> → [Import...].
Enter the path for the file to import in <File Path>.
4.
Click [Start Importing].
Loading Paper Information Settings
You can load paper information settings into the machine from files saved to a computer.
Click [Paper Information] for <Import/Export Individually> → [Import...].
Category:
Select the category of paper information to update.
File Path:
You cannot import a file while the machine is scanning.
» Remote UI » Import/Export Function » Loading Settings Information (Import Individually)
0JJC-1K9
