Available Settings Information Table with the Import All Function
The following cases may be possible for the Import All function.
Case A:
Importing all to your machine (Restoring the settings information to your machine for backups)
Case B:
Importing all to the same model machine (imageRUNNER ADVANCE C350iF/C250iF series)
Case C:
Importing all to the different model machine that supports the Import All function
In case C, the Import All function may not be enabled according to the model for importing. For more information, contact your local authorized Canon dealer.
The following settings information is available with the Import function in each case:
For more information, see the appropriate table. Settings/Registration items are grouped by purpose and stored in separate directories. If the Import All function can be used to import all of a primary setting's subsidiary settings, only the primary setting is listed in the table below.
In the following cases, even if you use the Import All function, the settings information may not be imported, or the value may be changed into the closest value.
There are no optional products or functions that use the set value.
The set value is not valid.
Settings/Registration Basic Information
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Settings
Paper Size Group for Auto Recog. in Drawer
A5/STMT Paper Selection
Register Custom Size
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Display Fax Function
Store Location Display Settings
Language/Keyboard Switch On/Off
Use Keyboard Shift Lock Feature
Display Remaining Paper Message
No. of Copies/Job Duration Status
Display Original Scanning Cleaning Area
Paper Type Selection Screen Priority
mm/Inch Entry Switch
ID/User Name Display On/Off
Display Remaining Toner Error Message
Setting Information
Case A
Case B
Case C
Preferences
Timer/Energy Settings
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Auto Reset Time
Restrict Auto Reset Time
Function After Auto Reset
Auto Sleep Time
Sleep Mode Energy Use
Auto Sleep Weekly Timer
Sleep Mode Exit Time Settings
Setting Information
Case A
Case B
Case C
Preferences
Network
Confirm Network Connection Set. Changes
TCP/IP Settings
IPv4 Settings
Use IPv4
IP Address Settings
IP Address
Subnet Mask
Gateway Address
DHCP
Auto IP
DHCP Option Settings
IPv6 Settings
Use IPv6
Stateless Address Settings
Manual Address Settings
Use DHCPv6
DNS Settings
DNS Server Address Settings
DNS Host/Domain Name Settings
DNS Dynamic Update Settings
mDNS SettingsUse mDNS/mDNS Name
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
Use FTP PASV Mode
Multicast Discovery Settings
Use HTTP
Proxy Settings
NetWare Settings
SNMP Settings
Dedicated Port Settings
Use Spool Function
Startup Settings
Ethernet Driver Settings
Firewall Settings
Setting Information
Case A
Case B
Case C
Preferences
External Interface
USB Settings
Accessibility
Key Repetition Settings
Reversed Display (Color)
Adjustment/Maintenance
Adjust Image Quality
Correct Density
Full Color Printing Vividness Settings
Fine Adjust Zoom
Adjust Toner Volume Used for Color Printing
Fill Area Image Adjustment Mode
Setting Information
Case A
Case B
Case C
Function Settings
Common
Paper Feed Settings
Paper Drawer Auto Selection On/Off
Feed Method Switch
Suspended Job Timeout
Paper Output Settings
Print Settings
Print Priority
Text/Photo Priority When ACS Is Set to Black
Output Report Default Settings
Register Characters for Page No./Watermark
Copy Set Numbering Option Settings
Secure Watermark/Document Scan Lock
Forced Secure Watermark/Document Scan Lock
Printer Driver Secure Watermark
Adjust Background/Character Contrast
Relative Contrast
Standard Value Set.
Latent Area Density
Adjust TL Code
Dot Size
Dot Density
Scan Settings
Streak Prevention
Feeder Scan Speed/Image Quality Priority
Remote Scan Gamma Value
Auto Online
Auto Offline
Generate File
High Compression Image Quality Level
OCR (Text Searchable) Settings
Trace & Smooth Settings
OOXML Settings
Specify Minimum PDF Version
Format PDF to PDF/A
Optimize PDF for Web
256-bit AES Settings for Encrypted PDF
Rights Management Server Settings
Document Scan Lock Operational Settings
Set Authentication Method
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Auto Collate
Select Color Settings for Copy
Send
Common Settings
E-Mail/I-Fax Settings
Register Unit Name
Communication Settings
Confirm SSL Certificate for SMTP TX
Confirm SSL Certificate for POP RX
Maximum Data Size for Sending
Default Subject
Specify Authentication User Dest. to Reply
Set Authentication User Destination to Sender
Allow Unregistered Users to Send E-Mail
Full Mode TX Timeout
Print MDN/DSN upon Receipt
Use Send via Server
Allow MDN Not via Server
Restrict TX Destination Domain
Autocomplete for Entering E-Mail Addresses
Fax Settings
Default Screen
Change Default Settings
Register Options Shortcuts
Register Sender Name (TTI)
Use Auth. User Name as Sender Name
ECM TX
Set Pause Time
Auto Redial
Check Dial Tone Before Sending
Fax TX Report
Fax Activity Report
Set Line
Line 1 to Line 2
Register Unit Telephone Number
Register Unit Name
Select Line Type
TX Start Speed
Confirm Entered Fax Number
Allow Fax Driver TX
Confirm Before Sending When Fax Dest. Incl.
Restrict Seq. Broadcast When Fax Dest. Incl.
Receive/Forward
Common Settings
Print on Both Sides
Reduce Fax RX Size
2 on 1 Log
Received Page Footer
Interrupt and Print RX Jobs
Handle Files with Forwarding Errors
Fax Settings
Store/Access Files
Network Settings
Memory Media Settings
Secure Print
Simple Authentication Settings
Only Allow Encrypted Print Jobs
Setting Information
Case A
Case B
Case C
Set Destination
Change Default Display of Address Book
Address Book PIN
Manage Address Book Access Numbers
Include Pswd. When Exporting Address Book
Register LDAP Server
Auto Search When Using LDAP Server
Register/Edit LDAP Search Conditions
Acquire Remote Address Book
Acquire Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Setting Information
Case A
Case B
Case C
Management Settings
Device Management
Device Information Settings
Device Information Delivery Settings
Register Destinations
Set Auto Delivery
Restrict Receiving Device Information
Restrict Receiving for Each Function
Report Settings
Set MEAP Authentication
Use MEAP Auth. When Receive
Display Job Status Before Authentication
Display Log
Audit Log Retrieval
Store Key Operation Log
Format Encryption Method to FIPS 140-2
License/Other
Message Board/Support Link
Remote Operation Settings
Use ACCESS MANAGEMENT SYSTEM
Data Management
Delete Existing Data Settings
Box Settings
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Memory RX Inbox PIN
Department ID Management Settings
Setting Information
Case A
Case B
Case C
Management Settings
User Management
System Manager/Contact Person Information Settings
Register PIN
Main Menu Settings
Setting Information
Case A
Case B
Case C
Main Menu Settings
Setting File
Favorite Settings
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Register/Edit Favorite Settings
Send
Common Settings
Fax Settings
Store/Access Files
Common Settings
Address Book
Setting Information
Case A
Case B
Case C
Set Destination
Rename Address List
Register One-Touch
Forwarding Settings
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
*If an address registered in the Remote Address Book is specified as the forwarding destination, the forwarding destination information of that address is not imported. However, if the exporting machine and importing machine use the same Remote Address Book, the importing machine can use the same forwarding settings. For information on the Remote Address Book, see "Specifying Destinations Using the Address Book (Remote)."
Quick Menu Settings
Setting Information
Case A
Case B
Case C
Quick Menu Settings
Button File
MEAP Application Setting Information
Setting Information
Case A
Case B
Case C
Workflow Composer
Flow Data File
Operation Setting File
MEAP User Setting Information
Data
Data
Paper Type Management Settings
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Web Access Settings
Setting Information
Case A
Case B
Case C
Web Access Settings
Favorites
Settings
If favorites are registered as the shortcut buttons or [Default Screen after Startup/Restoration] settings in the target machine for importing, the registered information is changed when importing the setting information of Web Access settings.
» Remote UI » Import/Export Function » Available Settings Information Table with the Import All Function
0JJC-1K7
