[Cyan]
-8 to +8; 0*
[Magenta]
-8 to +8; 0*
[Yellow]
-8 to +8; 0*
[Black]
-8 to +8; 0*
[Cyan]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Magenta]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Yellow]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Black]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Mode 1]:
Smoothly prints the edges of characters, lines, and diagrams that have dark colors. Select [Mode 1] to perform printing normally.
[Mode 2]:
Smoothly prints not only the edges of diagrams, but also the halftones inside the diagrams. Set [Mode 2] if large characters and halftones inside fat lines that have dark colors are misaligned and not printed smoothly when printing with [Mode 1] set.
[Mode 3]:
Smoothly prints characters and lines that have dark colors on a halftone background. Set [Mode 3] if large characters and halftones inside fat lines that have dark colors are misaligned, or when the edges of characters and lines that have light colors are uneven, and not printed smoothly when printing with [Mode 1] set.
[Mode 4]:
Smoothly prints the edges of various objects. Set [Mode 4] if the edges of large characters and fat lines that have light colors are uneven and not printed smoothly when printing with [Mode 1] set.
[Mode 5]:
Evenly prints images and halftone objects. Set [Mode 5] if the gradation bands of images and diagrams are uneven or the dithering patterns are uneven when printing with [Mode 1] set.
[Mode 6]:
Evenly prints all objects. Set [Mode 6] if the halftones of the entire image are misaligned and uneven when printing with [Mode 1] set.
If [Error Diffusion] is set in [Halftones], the [Mode 1] to [Mode 4] settings are disabled, and the same processing as [Mode 6] is performed.
The internal restriction value cannot be changed.
If [Grad. Priority] is selected, characters and lines may bleed.
If [Text Priority] is selected, the color may not match.
The Density mode is not available if you set [Toner Save] to [On].
Depending on the data to be printed, the Toner Save mode may not be applied even if you select [On].
If you select [On] for [Toner Save], very light or finely detailed images may not be printed clearly.
The Toner Volume Correction mode can only be applied to jobs in the PS mode and PDF mode.
If you select [Grad. Priority] for [Toner Volume Correction], characters and lines may bleed.
If you select [Text Priority] for [Toner Volume Correction], the color may not match.
