Editing a Security Policy
This section describes the procedure for changing the settings of a registered security policy. It also describes the procedure for enabling a security policy.
Press [Preferences] → [Network] → [TCP/IP Settings].
Press [IPSec Settings] for [TCP/IP Settings] → specify the following items → press [OK].
Enabling a Security Policy:
Changing the Priority of a Security Policy:
Deleting a Security Policy:
Changing the Settings of a Security Policy:
Select the security policy → press [Policy On/Off].
Select the security policy → press [Raise Priority] or [Lower Priority].
You can press [Print List] to print a list of the security policies and confirm their priorities.
Select the security policy → press [Delete].
Select the security policy → press [Edit].
Change the required items on the Edit screen → press [OK].
For more information on each setting, see "Registering a Security Policy."
» Network » TCP/IP Network Setup Procedures » Protocol Settings » IPSec Settings » Editing a Security Policy
0JJC-1H5
