Communication Environment Setup
This section describes how to set up the environment for communication between the machine and computers on your network. If you are configuring the settings for the first time, use the control panel of the machine.
After configuring the settings, you can change them using software other than the control panel of the machine. For more information, see "Settings/Registration Table."
Press [Preferences] → [Network].
Press [SNMP Settings] for [Network] → specify the SNMP v. 1 settings → press [OK].
If you want to use SNMP v. 1, press [On] for <Use SNMP v. 1> → set the MIB access permissions and community names.
The machine supports the SNMP v. 1 and SNMP v. 3 management functions. You can use them simultaneously. The [Read Only]/[Read/Write] functions of SNMP v. 1 and the security functions of SNMP v. 3, such as an encrypted communication path, enable you to manage devices more securely. The combinations of SNMP v. 1 and SNMP v. 3 functions you can use are shown below:
SNMP v. 1
SNMP v. 3
Description
<Use SNMP v. 1>
<MIB Access Permission>
<Use SNMP v. 3>
[On]
[Read/Write]
[On]/[Off]
You can set or browse each item of the machine with a utility that uses SNMP v. 1 to obtain information.
As the write access with SNMP v. 1 is enabled, the security functions of SNMP v. 3 are not available, regardless of the settings for <Use SNMP v. 3>.
[On]
[Read Only]
[On]
You can only browse each item of the machine with a utility that uses SNMP v. 1 to obtain information. Only users who have been assigned access rights can set each item of the machine with a utility that uses SNMP v. 3.
[On]
[Read Only]
[Off]
[Off]
[On]
Only users who have been assigned access rights can set or browse each item of the machine with a utility that uses SNMP v. 3.
[Off]
[Off]
You cannot set or browse each item of the machine with a utility.
If you want to use a Canon utility, the following settings are required in some cases:
Press [On] for <Use SNMP v. 1> → [Dedicated Comm. Settings]. Press [On] for <Dedicated Community> → [Read/Write] for <MIB Access Permission>.
Press [On] for [Dedicated Port Settings].
You can restrict the IP addresses of computers on which items can be set or browsed. If you restrict IP addresses, it is not possible to set or browse detailed information concerning the machine on computers other than those whose IP addresses are allowed to send or receive data, even if <Use SNMP v. 1>, <Use SNMP v. 3>, and [Dedicated Port Settings] are set to 'On'. For more information, see "TCP/IPv4 Settings" and "TCP/IPv6 Settings."
If you want to set a Dedicated Community:
If you want to set Community Name 1:
If you want to set Community Name 2:
Press [On] for <Dedicated Community> → select <MIB Access Permission> → press [OK].
Press [OK].
Press [On] for <Use SNMP v. 1> → [Set Community Name 1].
Press [On] for <Community Name 1> → select <MIB Access Permission> → press [Community Name].
Enter the community name → press [OK].
You can change the community name in [Community Name] to a name other than 'public'.
Press [OK].
Press [On] for <Use SNMP v. 1> → [Set Community Name 2].
Press [On] for <Community Name 2> → select <MIB Access Permission> → press [Community Name].
You can change the community name in [Community Name] to a name other than 'public2'.
Press [OK].
4.
Specify the settings for SNMP v. 3 → press [OK].
If you want to use SNMP v. 3, press [On] for <Use SNMP v. 3> → set the user and context.
If you do not want to use SNMP v. 3, proceed to step 5.
An SNMP v. 3 user with the following settings is registered by default. Delete or change these settings as necessary.
[User Name]:initial
<MIB Access Permission>: [Read/Write]
<Security Settings>: [Auth. Yes/Encry. Yes]
<Authent. Algorithm>: [MD5]
[Authent. Password]: initial
<Encryption Algorithm>: [DES]
[Encryption Password]: initial
If you want to add an SNMP v. 3 user:
If you want to confirm or change the SNMP v. 3 user settings:
If you want to delete an SNMP v. 3  user:
If you want to enable/disable SNMP v. 3 for a registered SNMP v. 3 user:
If you want to add a context:
If you want to change a context name:
If you want to delete a context:
Press [On] for <Use SNMP v. 3> → [User Settings] → [Reg.].
Press [User Name].
Enter the user name → press [OK].
Select the type of MIB access permission from the <MIB Access Permis.> drop-down list.
Select the type of security from the <Security Settings> drop-down list → press [Next].
[Auth. Yes/Encry. Yes]:
Applies authentication and encryption.
[Auth. Yes/Encry. No]:
Applies only authentication.
[Auth. No/Encrypt. No]:
Does not apply authentication or encryption.
Specify the settings according to the type of security.
<Security Settings>
Required Settings
Select [MD5] or [SHA1] from the <Authent. Algorithm> drop-down list → set [Authent. Password].
Select [DES] or [AES] from the <Encryption Algorithm> drop-down list → set [Encryption Password].
No settings are required.
Press [OK].
Press [On] for <Use SNMP v. 3> → [User Settings] → select the user to confirm/change the settings for.
Press [Details/Edit] → confirm/change the settings → press [OK].
Press [User Settings] → select the user whose settings you want to delete → press [Delete].
Press [OK].
Press [User Settings] → select the user you want to enable/disable SNMP v. 3 for → press [User On/Off].
Press [OK].
Press [Context Settings] → [Register].
Enter the name of the context to add → press [OK].
Press [OK].
Press [Context Settings] → select the context whose name you want to change → press [Edit].
Enter the context name → press [OK].
Press [OK].
Press [Context Settings] → select the context you want to delete → press [Delete].
Press [OK].
A context named 'NULL' is registered by default. The 'NULL' context cannot be deleted, and is not displayed on the Context Settings screen.
5.
Set the SNMP port monitoring function → press [Next].
To use the SNMP port monitoring function with Windows Vista/Server 2008/7/Server 2008 R2/8/8.1/Server 2012/Server 2012R2, set <Get Printer Mgmt Info from Host> to 'On'. If you set [Standard TCP/IP Port] for the printer driver port in the printer properties, the SNMP port monitoring function will be enabled automatically to obtain printer management information such as information on print applications and printer ports.
6.
Set [Reject SNMP Packets While in Sleep Mode] → press [OK].
Select [On] to discard the SNMP packets that are received when the machine is in the Sleep mode.
By setting [Reject SNMP Packets While in Sleep Mode] to 'On', you may be unable to access the machine from Canon software (imageWARE Series) or applications using the SNMP protocol.
7.
Press [Dedicated Port Settings] for [Network] → specify the required settings → press [OK].
Press [On] to set or browse detailed information on the machine with a Canon printer driver or utility.
8.
Press [Use Spool Function] for [Network] → specify the required settings → press [OK].
Press [On] to spool print jobs transmitted to this machine in the machine's hard disk.
When you spool a print job in the machine's hard disk, the time required to release a computer outputting a print job is shortened.
» Network » Network Environment Setup Procedures » Communication Environment Setup
0JJC-1FK
