Application Name
Displays the name of the application.
Installed on
Displays the date on which the application was installed.
Status
Displays the status of the application.
License
Displays the license status of the application.
Resource Information
Displays the resources being used by the applications.
Message
Status
Installed
Application has been installed but not started, or the application has not been restarted after stopping the application and then restarting the machine.
Started
Application is running.
Stopped
Application is stopped.
Starting
Application is starting up.
Stopping
Application is closing down.
Message
Status
Installed
An effective license file has been installed.
Not Installed
License file is disabled.
Excess
Expiration date and the types of counters set for the installed license file, and any counter value(s) exceeding the upper limit of the license file.
Invalid
Installed license file has exceeded its expiration date. Alternatively, current counter value has exceeded the upper limit of the license file.
(When a license file is set to many types of counters, it will expire when any counter exceeds the upper limit.)
Description
Timing of Update
Storage
Amount of hard disk being used. Shown in kilobytes (KB).
When installing/uninstalling applications.
Memory
Amount of memory being used. Shown in kilobytes (KB).
When starting/stopping applications.
Threads
Number of threads.
Sockets
Number of sockets.
File Descriptors
Number of file descriptors.
You cannot start applications whose required license file has not been installed.
When the resources required for memory, threads, sockets, or file descriptors has run out, the application will not start, even if you click [Start].
If you start/stop an application, you may need to restart the computer to activate the driver settings of USB devices. Follow the instructions on the screen and restart the computer.
