You can search for and specify addresses registered in the address book for this machine.
Press [Fax] → [Address Book].
Select the destination → press [OK].
You can select multiple destinations.
For instructions on searching for destinations registered in the Address Book, see "Address Book Screen."
If you select a destination that is stored with an access number, press [Other Ops.] →[Access No.] → enter the access number using - (numeric keys). If you press [Addresses without Access Number], the destinations that are not managed with an access number are displayed.
To cancel a selected destination, select the destination again.
The Local Address Book data can be saved and imported using the Remote UI. (See "Loading Settings Information (Import Individually).")
If you select only one destination, press (Start) to send from the Address Book screen.
» Fax » Sending/Receiving a Fax » Specifying Destinations » Specifying Destinations Using the Address Book (Local)
0JJC-0K8
