Originals must all be the same size.
[Portrait]:
Portrait refers to an original in vertical orientation:
the shorter edges are at the top and bottom of the original.
[Landscape]:
Landscape refers to an original in horizontal orientation:
the shorter edges are at the left and right of the original.
2 on 1:
Left → Right
4 on 1:
Upper Left → Upper Right → Lower Left → Lower Right
The machine automatically selects the copy ratio depending on the selected paper size.
If you set [N on 1], the Center Shift mode is also automatically set.
Printing performance may not be optimal, depending on the combination of settings.
