Sending an E-mail to Multiple Destinations
If you register a group that includes multiple e-mail addresses in the address book, you can send to all of the e-mail addresses included in that group at once by selecting that group as the destination.
Benefits of Sending to a Group
You can send an e-mail to multiple destinations at once.
Required Condition
Network settings are set.
E-mail settings are specified.
This section describes how to store three previously registered e-mail addresses as "Group A," and send a two page e-mail to that group.
The screens may differ, depending on the model of the machine and on attached optional products.
Follow the procedures below.
Registering a New Group
Sending an E-Mail
You can perform this procedure using the touch panel display or the Remote UI. Using the Remote UI, you can perform this operation with ease.
Access the Remote UI → click [Address Book] → select an address list from the Address Lists page.
Click [Register New Group].
Enter 'Group A' in <Group Name> → click [Select Destination...] for <Members List>.
4.
Select the e-mail addresses that you want to store in the group → click [OK].
Using the Touch Panel Display
Press
(Settings/Registration) → [Set Destination] → [Register Destinations] → [Register New Dest.] → [Group].
Press [Name] → enter 'Group A' as the new group name → press [Next].
Press [Add from Address Book] → select the e-mail addresses that you want to store in the group → press [OK].
Repeat this step two times, and select total of three e-mail addresses.
A new group destination is registered.
Press [Scan and Send] on the Main Menu screen → [Address Book] → select [
] from the drop-down list.
If the Main Menu screen is not displayed, press [Main Menu].
Select the newly registered destination [Group A] → press [OK].
Place the original in the feeder or on the platen glass → press
(Start).
The e-mail is sent.
4.
Press [Status Monitor/Cancel] → [Send] → [Log] → check that the e-mail was sent successfully.
If the result is [OK], the e-mail was sent successfully.
If the result is [NG], the e-mail was not sent because of an error.
