imageRUNNER ADVANCE machines do not support e-mail reception.
Fax
E-Mail
I-Fax in
Simple Mode |
I-Fax in
Full Mode |
Intranet
Fax |
Transmission Cost
Per transmission
Fixed rate
(leased line) |
Fixed rate
(leased line) |
Fixed rate
(leased line) |
Fixed rate
(office LAN) |
Speedy
Yes
No
No
No
Yes
Confirm Transmission
Yes
No
No
Yes
Resolution
Approx. 200 dpi
Up to 600 dpi
Up to 600 dpi
Up to 600 dpi
Up to 600 dpi
Paper Size
Up to LGL
Up to LGL
Up to LGL
Up to LGL
Up to LGL
File Format
TIFF
JPEG, TIFF, PDF, XPS, OOXML
TIFF
TIFF
TIFF
E-Mail Settings
Example Setting
imageRUNNER ADVANCE
Setting |
Primary DNS Server
10.120.5.11
Press
(Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [DNS Settings]. |
Secondary DNS Server
10.120.10.55
Host Name
IRADV
Domain Name
example.com
E-Mail Address Acquired for the imageRUNNER ADVANCE Machine
01xxx@example.com
Press
(Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Communications Settings]. |
SMTP Server
SMTPSV.example.com
POP Server
POPSV.example.com
POP Login Name
IRADV
POP Password
ACC123
Transmission Authentication Method
POP before SMTP
Maximum Data Size for Sending
2 MB
Press
(Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Maximum Data Size for Sending]. |
Required Condition
Network settings are set.
E-mail settings are specified.
Primary DNS Server Address, Secondary DNS Server Address:
Enter the IP address of the primary server and secondary server.
Host Name:
Enter a name of your choice. This is equivalent to the computer name of a computer.
Domain Name:
Enter the name of the network domain that the imageRUNNER ADVANCE machine belongs to. (The part of the e-mail address after the "@.")
Perform DNS Dynamic Update
Select this if you have a dynamic DNS server.
Deselect this if you do not have a dynamic DNS server. |
To specify these settings from the control panel of the machine, press
(Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [DNS Settings].If the continual issuing of packets from the imageRUNNER ADVANCE machine to the DNS server is causing excessive network traffic, you can disable dynamic DNS updating after communication is complete.
However, this is only if you have a server in your company, and your environment is not a DHCP environment (your environment must use a fixed IP address and host names). |
SMTP RX:
Not required to be set. This setting is for Intranet Fax.
POP RX:
Set this to 'On' for environments sending with POP before SMTP or when using a POP server to receive I-faxes.
SMTP Server:
The IP address or host name of the mail server used for sending.
E-Mail Address:
The e-mail address to set for the imageRUNNER ADVANCE machine.
POP Server:
The IP address or host name of the mail server (POP server) used in environments sending with POP before SMTP.
POP Login Name
The log in name used to access the POP server (the part of the e-mail address before the "@").
POP Password:
The password used to access the POP server.
Confirm
Reenter the POP password for confirmation.
POP Interval:
Set the interval for automatically accessing the POP server to perform POP reception.
(This refers to the interval that the imageRUNNER ADVANCE machine goes to the mail server to check for e-mail.) |
(Settings/Registration) → [Functions Settings] → [Send] → [E-Mail/I-Fax] → [Communication Settings].The I-fax function of imageRUNNER ADVANCE machines uses the SMTP protocol for transmission.
It is not necessary to specify the settings on this page when accessing a server that does not require transmission authentication.
Allow SSL (POP):
Select this to use SSL for POP communication. Select the POP authentication method from the drop-down list, according to your internet provider.
Use POP Authentication Before Send *:
Select this for mail server environments that require POP before SMTP.
Confirm SSL Certificate for POP RX:
Select this to confirm whether the SSL server certificate is valid when receiving with POP. Select [Add CN to Verification Items] if you want to confirm the CN (Common Name).
Allow SSL (SMTP TX):
Select this to use SSL for SMTP transmission.
Use SMTP Authentication (SMTP AUTH)**:
Select this for mail server environments that require SMTP authentication (SMTP AUTH).
User:
Enter the user name to use for logging in to the SMTP server.
Password, Confirm:
Enter the password to use for logging in to the SMTP server.
Display Authentication Screen When Sending:
Select this to enter the authentication information each time sending is performed.
Confirm SSL Certificate for SMTP TX:
Select this to confirm whether the SSL server certificate is valid when sending with SMTP. Select [Add CN to Verification Items] if you want to confirm the CN (Common Name).
Allow SSL (SMTP Receive):
Set this to 'On' for mail server environments that require communicated data to be encrypted.
If the SMTP server does not support encryption, data is not encrypted even when you select [On] for <Allow SSL>.
Maximum Data Size for Sending:
You can set the maximum data size for outgoing e-mail messages and I-fax documents. If an e-mail message exceeds this data size limit, it is split up into several e-mail messages before being sent.
Set the maximum data size for sending lower than the data limit for the mail server. If you enter '0' MB as the data size, there is no size limit on the data that is sent. |
Default Subject:
You can enter a default subject to use whenever you do not enter a subject when sending a job.
The default setting is 'Attached Image'. |
(Settings/Registration) → [Functions Settings] → [Send] → [E-Mail/I-Fax Settings]. |
On:
Select this to divide the attached data by its size. This setting requires the e-mail software to have a "merging function."
Off:
Select this to divide the attached data by its page boundaries. This setting does not require the e-mail software to have a "merging function."
If a single page of an attached image exceeds the value set for Maximum Data Size for Sending, an error occurs and sending cannot be performed.
If the Main Menu screen is not displayed, press [Main Menu].
If you select [PDF], [XPS], [TIFF], or [OOXML], you can use the Divide into Pages mode.
You can select the following PDF, XPS, or OOXML types:
Trace & Smooth*
Compact
OCR (Text Searchable)
Encrypted*
Add Digital Signatures
Apply Policy*
* This is only valid for PDF file format.
For more information, see Scanning the Original and Sending to a Computer in "Digitizing Paper Documents."
You can specify e-mail address destinations for the Cc and Bcc addresses. You can specify a maximum of 256 destinations at the same time for the Cc and Bcc addresses.
On:
Select this to send each page as a separate file when sending a multiple page original. TIFF images are sent as single TIFF images.
Off:
Multiple pages are sent as a single file. TIFF images are sent as multi TIFF images.
[JPEG]
Sends the file in the JPEG format, if you select a color mode other than Black-and-White.
[TIFF]
Sends the file in the TIFF format, if you select Black-and-White for the color mode.
[PDF]
Sends the file in the PDF file format, regardless of the color mode.
[XPS]
Sends the file in the XPS file format, regardless of the color mode.
[OOXML]
Sends the file in the Office Open XML (pptx) format only if you select the Full Color mode or the Grayscale mode for the color mode.
If JPEG format is selected, [Divide into Pages] is set to 'On'.
Settings
Sample Setting
Default Setting
Sender Name
CANON MJ INC.
Address of your machine
File Name
"Notification"
Time string (200909051530)
Subject
"Notification Message"
Body
"To whom it may concern"
Empty
Reply to
01xxx@example.com
You can only select settings stored in advance for "Sender Name" and "Reply to." You cannot enter a new destination on the Options Screen. Store the destination in Settings/Registration. The "Sender Name" displayed on the reception screen is the unit name set for the imageRUNNER ADVANCE machine that is sending. The "Sender Name" setting is not reflected.
When you send documents that always have the same "Subject" or "Body", such as monthly reports or order forms, it is useful to store the send settings in favorite settings. You can also register a destination in the favorite settings.
