Inserting and Removing Memory Media
You can use USB memory by inserting it into the USB port of the machine.
Make sure you follow the following procedure to remove the memory media from the machine. If the memory media is removed from the machine in a way other than the procedure below, the memory media and the machine may be damaged.
The corresponding format for the memory media is only FAT32.
Before inserting the memory media, make sure that the memory media is facing the correct direction. If the memory media is inserted incorrectly, the memory media and the machine may be damaged.
Inserting Memory Media
If you want to insert the USB memory into the USB port of the machine:
Insert the USB memory into the USB port on the right side of the Platen Glass of the machine.
A message indicating that the memory media is connected and the removal key appear on the touch panel display.
The message may not appear depending on the current status of the machine, or the login service you are using.
This section describes how to remove the memory media from the machine safely.
Press .
Select the memory media to remove → press [Remove].
Press [OK].
If the message indicating it is OK to remove the memory media does not appear, repeat steps 2 and 3.
4.
Remove the memory media from the USB port.
5.
Press [OK].
The message and removal key are displayed if [Use MEAP Driver for USB Input Device] is set to 'Off'. (See "Using the MEAP Driver for USB External Storage.")
» Basic Operations » Inserting and Removing Memory Media
0JJC-01L
