[Space]:
Press to insert a space between the area code and the local fax number.
Use to insert a country code. Press [+] after the country code, before the fax number.
Press to move the position of the cursor.
[Backspace]:
Press to delete the last number entered.
Select Line Type mode is not available in some regions.
You can set to display/print the Sender Name instead of the name stored as the unit's name from [Sender Name (TTI)] in [Options]. (See "Selecting the Sender's Name When Sending a Fax.")
The unit's name can be printed on the received documents as the Sender Name.
