Registering/Editing/Deleting Custom Paper Sizes
You can register custom paper sizes, assign them names, and edit or delete them as necessary. This mode is useful for registering frequently used paper sizes.
Press [Preferences] → [Paper Settings] → [Register Custom Size].
Select the desired setting.
To register/edit a custom paper size:
To register the name for a custom paper size:
To delete a custom paper size:
Select a button ([S1] to [S4]) to register or edit a custom paper size → press [Register/Edit].
Press [X] and [Y] → enter each value → press [OK].
Select a button ([S1] to [S4]) to name → press [Rename].
Enter a new name → press [OK].
Select the custom paper size that you want to delete → press [Delete].
Press [Yes].
4.
Press [Close].
Confirm the contents to be deleted.
If you select a button that already has settings stored in it, the settings are displayed.
If you make a mistake when entering values, press (Clear) → enter the correct values.
You can also name buttons with no settings stored in them.
For instructions on entering characters, see "Entering Characters."
If you press [OK] without entering any characters, the button name reverts to its current name (default S1 to S4).
The paper size settings stored in memory are not deleted, even if the machine's main power switch is turned Off.
» Settings/Registration » Preferences » Paper Settings » Registering/Editing/Deleting Custom Paper Sizes
0JJC-050
