      0SU0-06S
      Machine Specifications
      Name
      Canon imageRUNNER 1435P
      Type
      Desktop
      Power Source
      110 to 127 V AC, 50/60 Hz, 7.8 A
      Power Consumption
      Maximum power consumption
       1.5 kWh or less
      Average consumption during standby mode
      Approximately 15 W
      When the machine is in the sleep mode*1
      Approximately 2.0 W
      When the power switch is turned OFF
      0.1 W
      Warm-up Time*2
      After powering ON
      20 seconds
      Returning from the sleep mode
      7.8 seconds
      Weight
      Approximately 47.3 lb (21.44 kg)
      Dimensions (H x W x D)
      15 1/8" x 21 1/2" x 18" (382.5 x 545 x 457 mm)
      Installation Space (W x D)
      30 3/8" x 18" (772.1 × 457 mm) (when the multi-purpose tray is extended)
      Number of Tones
      256
      Memory Capacity
      512 MB
      Acceptable Paper Stock
      Printable Range
      *1 Depending on the system and conditions of use, these values may differ.
      *2 Activation time may vary, depending on the environment and conditions under which the machine is being used. (At a room temperature of 68 °F [20°C] in all above cases.)
