      0SU0-062
      IPSec Policy List
      You can print a list to check the policy names and IPSec settings currently registered in the machine.
      Example:
      1
      Press .
      2
      Use / to select <Output Reports>, and press .
      3
      Select <Print List> <IPSec Policy List>.
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      4
      Check that the size and type of paper displayed on the screen is loaded in the machine, and press .
      5
      Select <Yes>, and press .
