Name
Canon imageRUNNER 1435iF / 1435i / 1435
Type
Desktop
Power Source
110 to 127 V AC, 50/60 Hz, 7.8 A
Power Consumption
Maximum power consumption
1.5 kWh or less Average consumption during standby mode
Approximately 15 W When the machine is in the sleep mode*1
Approximately 2.0 W When the power switch is turned OFF
0.1 W |
Warm-up Time*2
After powering ON
20 seconds Returning from the sleep mode
7.8 seconds |
Weight
Approximately 52.3 lb (23.74 kg) imageRUNNER 1435
Approximately 49.3 lb (22.34 kg) |
Dimensions (H x W x D)
18 3/4" x 21 1/2" x 18" (475.3 x 545 x 457 mm) imageRUNNER 1435
16 5/8" x 21 1/2" x 18" (422.5 x 545 x 457 mm) |
Installation Space (W x D)
30 3/8" x 18" (772.1 × 457 mm) (when the multi-purpose tray is extended)
Number of Tones
256
Memory Capacity
512 MB
Acceptable Documents
Acceptable Paper Stock
Printable Range
Scan Range
*1 Depending on the system and conditions of use, these values may differ.
*2 Activation time may vary, depending on the environment and conditions under which the machine is being used (At a room temperature of 68 °F [20°C] in all above cases).
