When copying documents that are smaller than the output paper size, frame lines may appear around the edges in the copied image. When copying facing pages from thick book, dark borders may appear. <Erase Frame> enables you to erase these frame lines and dark borders.
The width of the frame to erase is increased or decreased relative to the <Copy Ratio> setting.
<Erase Frame> is not available when using <2 on 1>/<4 on 1>, or <ID Card Copy>.
<Erase Frame>
<On>
Specify the width of the frame to erase
Select the document size on the <Scan Size> screen
Frame Width
to specify the size of the frame width, and use
to move the cursor back and forth between the whole number and fraction (1/16" to 1 15/16" [1 to 50 mm]).
