» Setting Menu List » Contents of the Menu Options » Fax Settings
Fax Settings
About the menu options in the following chart
Default settings are highlighted in bold.
The settings marked with "*A" cannot be imported or exported via the Remote UI.
Basic Settings
Settings
Descriptions
Register Unit Telephone Number
You can register the fax number of the machine.
See the Starter Guide.
Select Line Type
Select a line type.
Pulse, Tone
Off-Hook Alarm
Specify whether to sound an alarm when the telephone handset is left unhooked and adjust the volume.
Off
On:
Off-Hook Alarm Volume: 1 to 3
TX Function Settings
Settings
Descriptions
Change Defaults
You can register scan settings for documents.
Register Unit Name (Fax)
Register your name or company's name (sender's name).
ECM TX
You can specify whether to use ECM.
Off, On
Pause Time
You can specify the number of seconds for the pause time.
1 to 2 to 15 (seconds)
Auto Redial
You can specify whether to redial when fax documents cannot be sent.
Off, On
Redial Times
You can specify the number of times to redial.
1 to 2 to 10 (times)
Redial Interval
You can specify the interval between redials.
2 to 99 (minutes)
Redial When Err Occurs
You can specify whether to redial when a send error occurs.
Off, On
Sender ID
The sender ID is printed at the top of each page that you are sending, along with the fax number and sender's name. This helps the recipient to identify the sender.
Off, On
Print Location
Select the location where the Sender ID is printed.
On Image, Above Image
Mark No. as: TEL/FAX
Select the text to add in front of the number.
FAX, TEL
Check Dial Tone Before Sending
You can specify whether to dial after checking the dial tone when sending fax documents.
Off, On
RX Function Settings
Settings
Descriptions
ECM RX
Off, On
Incoming Ring
Set whether or not to ring the external telephone when <RX Mode> is set to <Auto> or <Fax/Tel Auto Switch>.
Off
On:
Ring Times: 1 to 2 to 99 (times)
Remote RX
You can specify whether to use the "remote receiving function" enabling you to receive fax documents by dialing an ID number even in the middle of a telephone call.
Off
On:
Remote RX ID: 00 to 25 to 99
Auto RX Switch
Set the incoming call ring time before the machine switches to the fax mode automatically. This option can be enabled when the <RX Mode> is set to <Manual>.
Off
On:
Incoming Ring Time: 1 to 15 to 99 (seconds)
RX Print Settings
Settings
Descriptions
2-Sided Printing
Enable this option to print on both sides of paper. This saves excessive paper consumption.
Off, On
Reduce RX Size
You can reduce the size of received documents and print them.
Off
On:
Reduction Ratio: Auto, 97, 95, 90, 75 (%)
Reduction Method: Vertical/Horizontal, Vertical Only
RX Page Footer
You can specify whether to print information such as reception date when printing received documents.
Off, On
Continue Printing When Toner Is Low
Specify whether to continue printing received documents when the toner is nearly empty.
Off, On
Fax Setup Guide*A
Specify initial fax settings and connect the telephone cable.
07K4-0RY
