Before Replacing the Toner Cartridge
07K4-0WE
When the toner nearly runs out, follow the steps in the procedure below before replacing the toner cartridge. The machine continues printing until the toner runs out completely.
1
Open the front cover while holding down the open button.
2
Remove the toner cartridge.
3
Gently shake the toner cartridge five or six times to evenly distribute the toner inside the cartridge.
4
Insert the toner cartridge.
Fit (A) on both sides of the toner cartridge into the guides located on both sides of the machine and slide the toner cartridge into the machine until the toner cartridge comes to rest and is held against the back of the machine.
5
Close the front cover.
If you cannot close the front cover
Make sure that the toner cartridge is installed correctly. Do not try to forcefully close the toner cover, as this may damage the machine.
If there are white lines in the print result or it is blurred or distorted even though the above operations have been performed, replace the toner cartridge with a new one.  " Replacing the Toner Cartridge"
