Category
Top » Troubleshooting » Printing Results Are Not Good » Toner Smudges and Spatters Appear around Text and Images
Category Top
Error Codes
When a Power Failure Occurs
Clearing Jams
Document Jams in the Feeder
Paper Jams in the Output Area
Paper Jams in the Multi-Purpose Tray
Paper Jams in the Paper Drawer (Drawer 1 or 2)
Paper Jams in the Back Cover and Duplex Unit
Paper Jams in the Front Cover
Paper Jams in the 2-sided Transport Guide
When <Incorrect Size/Setting> Appears
Onscreen Messages
Troubleshooting
Paper Feeding Problems
Fax Problems
Sending Problems
Cannot Send a Fax
Receiving Problems
Modes Cannot Switch Automatically between Telephone and Fax
Faxes Cannot Be Printed, or the Images on Printouts Are Spotted or Distorted
Copying Problems
The Copy Output Is Hardly Readable and Copied Poorly
Printing Problems
Cannot Print Documents from a Computer
Cannot Print over a TCP/IP Network
Scanning Problems
Cannot Scan a Document
Telephone Problems
Network Problems
Wired LAN Troubles
Checking Network Connection (Wired LAN)
Wireless LAN Troubles
Checking Network Connection (Wireless LAN)
Installation and Uninstallation Problems
Miscellaneous Problems
Paper Curls
Paper Creases
Vertical Streaks Appear on the Output
The Bottom Edge of Paper or Following Paper Has Smudge Marks
A Portion of the Page Is Not Printed
Uninstalling the Software
When a Problem Cannot Be Resolved
Collapse all|Expand all
07K4-0UX
Try one of the following to solve the problem.
<Cause 1> The paper type loaded is not appropriate.
Solution
Make sure that the number of sheets or the paper type loaded in the paper drawer or multi-purpose tray meets the paper specifications.
<Cause 2> Due to the paper type (for example, heavy paper) or usage conditions (for example, dry conditions), toner smudges and spatters appear on the output.
Solution
Change the <Special Mode U> setting to <On> from the operation panel.
Set this setting to <Off> unless the above mentioned problem occurs.
The print quality may become lower when this setting is enabled, depending on the paper type used (for example, thin paper) or usage conditions (humid conditions).
