Precautions on 2-Sided Printing
Do not touch your document when making 2-sided printing until the process is complete. After printing on the front side is complete, the document is partially output, reserved, and fed into the machine again for printing on the back side.
Be sure to close the sub-output tray before making 2-sided printing.
If not securely attached, documents may not be fed properly, or jammed.
Open the lower rear cover.
Securely place the blue color paper size switch lever (A).
Close the lower rear cover.
For instructions on how to display the printer driver screen, see "Printing" or "Configuring the Default Print Settings."
For details about the various settings in the [Detailed Settings for Booklet] dialog box, view the online help. (See "Viewing the Online Help.")
You cannot specify the [Finishing] options in the [Finishing] sheet when performing booklet printing.
The display may differ according to the operating system, as well as the type and version of the printer driver.
