Precautions on 2-sided printing
Do not touch your document when making 2-sided printing until the process is complete. After printing on the front side is complete, the document is partially output, reserved, and fed into the machine again for printing on the back side.
Be sure to close the sub-output tray before making 2-sided printing.
Printing to the back side of printed document (Manual 2-sided printing)
Two-sided printing can be performed manually using a printed document. Place a printed document in the multi-purpose tray to print on the back side*.
To print on the back side of a printed document, smooth out the curling edges of the sheets and place them one by one in the multi-purpose tray.
If not securely attached, documents may not be fed properly, or jammed.
Open the lower rear cover.
Securely place the blue color paper size switch lever (A).
Close the lower rear cover.
For instructions on how to display the printer driver screen, see "Printing" or "Configuring the Default Print Settings."
The page sizes for which 2-sided printing is available differ according to printer model. For details, view the online help. (See "Viewing the Online Help.")
The display may differ according to the operating system, as well as the type and version of the printer driver.
