Category
Top » Printing » Printing Documents from a Computer » Configuring Port Settings over a TCP/IP Connection
Category Top
Preparing to Print from Your Computer
Setting Up Printer Sharing
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Sheet
[Finishing] Sheet
[Paper Source] Sheet
[Quality] Sheet
[Device Settings] Sheet
Scaling Documents
1-sided Printing and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Checking and Deleting Print Jobs/Checking Print Job History
Checking and Canceling Print Jobs
Changing printer settings (Items to Be Specified Using [Menu] Button)
Printing Documents from a USB Memory (Media Printing)
Summary of Media Printing
Printing Fundamentals (USB Memory)
Selecting a file to print
Changing Print Settings
Attention (Changing Print Settings)
Printing Files as a List (Index Printing)
Changing File Name Display Formats
Changing the Default Values for Media Printing
Collapse all|Expand all
07K4-0A7
Configure port settings on your computer to print to the machine.
Configure port settings on your computer when:
Steps to take
Installing the printer driver using [Add
Printer].
Note that a different IP address is assigned to the installed printer driver. To use the IP address of the machine, configure port settings on your computer after installation.
Changing the IP address of the machine.
Configure port settings on your computer to use the IP address of the machine.
The dialog box that appears on your computer
The dialog box may vary slightly, depending on the version of your operating system.
1
Open the printer folder.
2
Right-click the icon for the machine and select [Printer properties] (or [Properties]).
3
Click the [Ports] tab.
4
Click [Add Port].
5
Select [Canon MFNP Port] for [Available port types] and click [New Port].
6
Click [Auto Detect].
 When you cannot perform Auto Detect
Enter the IP address or MAC address of the machine manually.
You can check the IP address of the machine in "Checking IP Address Settings."
You can check the MAC address of the machine in "Checking the MAC Address."
7
Select the detected printer and click [Next].
8
Click [Add].
9
Click [Finish].
10
Click [Close].
11
Click [Apply].
