] (Menu) to enter the menu screen.
] or [
] to scroll up and down the menu.
] to select the item and proceed to the next screen.
] (Back) or [
What you want to do
Screen example
Procedure
Adjust levels such as density on the scale
Press [
] or [ ] to adjust the level. |
Set the timer
Press [
] or [ ] to specify the value.
Enter numbers or characters such as a PIN
You can enter numbers or characters using the numeric keys.
To confirm the entered number or character:
Press [OK].
Select <Apply> displayed on the screen using [
] or [ ] and press [OK]. |
] (Menu) to exit the menu screen and return to the default screen.
If you press [
] (Menu) before you press [OK]The changes made to the settings are not saved.
