CAUTION |
Precautions to take when you get toner onto your hands or into clothing
If toner gets on your hands or clothing, wash them immediately with cold water.
The toner sets onto hands or into clothing if you try to wash it with warm water. Once it is set, you can hardly remove the toner stains.
Be careful not to scatter the toner.
Do not pull out the sealing tape forcefully or stop pulling the tape halfway, as this may cause toner to spill out.
If toner gets into your eyes or mouth, wash them immediately with cold water and consult a physician.
Precautions to take when lowering the scanning platform
Be careful not to catch your fingers.
When pulling out the sealing tape
Do not pull the sealing tape at an angle or sideways. If the tape breaks, it may not be pulled out completely.
If the sealing tape is still hanging outside the toner cartridge, pull it out completely.
If the tape remains inside the toner cartridge, it may cause poor print quality. If you are using the Fax, please note that you can only print the received data once, because the received data is deleted once it is printed.
Disposing of the removed sealing tape
Dispose of the sealing tape according to local regulations.
Do not leave the toner cover open for an extended period of time when the toner cartridge is installed.
This may result in print quality deterioration.
