Solution 1
Perform the following procedure in the printer driver.
Solution 2
You can specify the same setting from the printer's control panel.
Solution
Load the paper properly.
Solution 1
Data is printed with a margin of 0.20 in. (5 mm) (0.39 in. (10 mm) for envelopes). Provide a margin around the data.
Solution 2
Perform the following procedure if you are using the printer driver.
PCL/UFR II Printer Driver
PS Printer Driver
See Help of the PS printer driver.
