The Printer Cannot Be Searched for
If the printer cannot be searched for when you are in the process of installing the printer driver, perform the following procedure.
1
Make sure that the LAN cable is connected properly, and the printer is turned ON.
2
Click [Search Again] to search again for the printer on the network.
Make a search again for the printer on the network.
Install the printer driver by following the procedure for automatically searching for a printer on a network described in the “Printer Driver Installation Guide.”
For details on the procedure for viewing "Printer Driver Installation Guide", see "
Installation."
If the printer cannot be searched for (no devices are displayed) even by performing the above procedure
<Solution>
Set [Interface Selection] in [Network] to [On].
Set the IP address.
Recover your printer from Sleep mode or set [Sleep Mode] to [Low (Panel Sleep)] or [Off].
