Changing the Settings Using Web Browser (Remote UI)
1
Start the Remote UI, and then log in as Administrator.
2
Click [Settings/Registration].
3
Select [Network] from the [Preferences] menu.
4
Click [Spooler].
5
Click [Edit...].
6
Specify the setting for the spooler function.
(1)
When using the spooling function, select the [Use Spooler] check box.
(2)
Click [OK].
7
Perform a hard reset or restart the printer.
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
Select [Device Control] from the [Output/Control] menu.
Select [Hard Reset], and then click [Execute].
» Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (Common to Each Protocol) » Setting the Spooling Function » Changing the Settings Using Web Browser (Remote UI)
07E3-07U
