When wiping the feed roller, use a cloth dampened with water and well wrung out. Do not use cleaning agents or detergents, including ones containing grease or oil.
When cleaning the feed roller, make sure not to touch the rubber pad directly with your hand.
(1)
While pushing the feed roller to the left, remove it as shown in the figure.
(2)
While pulling the feed roller down, remove it from the compartment.
(1)
Insert the left shaft of the feed roller.
(2)
Insert the right shaft while pushing the feed roller in the direction (1).
At this time, do not apply excessive force to the feed roller.
Hold the right shaft between your fingers when installing the feed roller. Do not hold the left shaft.
