e-Manual
Top
Site map
Help
Contents
Search
Previous
Next
Print this topic
Chapter:
Before You Start
Important Safety Instructions
About This Printer
Maintenance
Printer Installation
Installing the Software
Basic Printer Operations
Printing on Various Types of Paper
Useful Printing Functions
Configuring the Network Settings (Sharing the Printer)
Managing the Printer
Security Settings
MEAP
Troubleshooting
Appendix
Expand all
Collapse all
Chapter Top
Printing Cannot Be Performed
Printing Cannot Be Performed (USB Connection)
Printing Cannot Be Performed (LAN Connection)
Printing Cannot Be Performed (via the Print Server)
The Print Server for Connection Cannot Be Found
The Shared Printer Cannot Be Accessed
The Printer Takes a Long Time to Start the Print Job
You Cannot Turn the Printer ON
All the Indicators on the Network Interface Are Off
You Cannot Install the Printer Driver
The Printer Is Not Recognized Automatically
The Printer Cannot Be Searched For
You Cannot Uninstall the Printer Driver
The Printer Driver Settings Cannot Be Changed
"Profiles" Cannot Be Selected or Edited
The Status of the Paper Feeder Cannot Be Obtained Automatically
Paper Jams
Attention (Paper Jams)
Clearing Paper Jams (Multi-purpose Tray)
Clearing Paper Jams (Paper Drawer)
Clearing Paper Jams (Duplex Unit)
Clearing Paper Jams (Inside the Output Area)
Clearing Paper Jams (Inside the Front Cover)
Cleaning the Feed Roller
The Message Indicator Is On
A Message Appears in the Control Panel
Poor Printout Results
Paper Curls
Paper Creases
White Streaks (Lines) Appear
Printing Is Uneven
Printed Pages Have White Specks
Toner Stain or Toner Peeling Occurs
The Printed Paper Has Smudge Marks
The Printed Paper Has Vertical Streaks
Smudge Marks of Spattering Toner Appear around the Text or Patterns
The Back of the Printed Paper Has Smudge Marks
The Overall Print Result Is Dark
Residual Images Appear on Non-printed Areas
White Dust Is Attached to the Printed Transparencies
The Overall Print Result Is Faint
The Printing Position Is Skewed
A Portion of the Page Is Not Printed
Data Is Reduced and Printed
The Next Page Is Printed from Halfway across the Previous Page
Printed Data Lies outside Paper
Blank Paper Is Output (Nothing Is Printed on the Paper)
The Overall Surface of the Paper Is Printed in Black Completely
The Last Page Cannot Be Printed
Unreadable Characters Are Printed
The Printout Is Different from What Is Displayed on Screen (Windows XP and Server 2003)
The Flap of the Printed Envelope Sticks
Multiple Sheets of Paper Are Fed at a Time
Cleaning the rubber pad in the paper drawer
Other Problems
The Keys on the Control Panel Do Not Function
The SD Card Cannot Be Used
Jobs Cannot Be Saved
SSL Cannot Be Enabled
When SSL Is Enabled, the Remote UI Does Not Start, or the IPP Printing Cannot Be Performed
The Printer Cannot Be Accessed from the Remote UI or Network Related Utility Software
Restricting the Users Is Not Possible
Noise Is Heard during Printing
If You Cannot Solve a Problem
Print all
Keyword:
Search options
Search all chapters
Search from below chapters
Before You Start
About This Printer
Maintenance
Security Settings
MEAP
Troubleshooting
Appendix
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Top
Troubleshooting
08X4-0KJ
Perform the following procedure.
<Cause>The fixing roller is dirty.
Solution
Clean the fixing roller.
Cleaning the Fixing Roller of the Printer
Back to Top
