» MEAP » List of Error Messages (MEAP) » Errors Relating to the [Enhanced System Application Management] Page
The currently set login service
Login services that will be enabled after the device is restarted
Default Authentication login services
The currently set login service can be uninstalled after the device is restarted.>
Cannot start this application because there is no distributable software in the application. Get a distributable software.
Problem
The application cannot be started because it does not contain any redistributable modules.
Action
Contact the application developer.
Cannot start this application because the number of bootable applets has exceeded the limit. Start this application after stopping other applications.
Problem
The application that you are attempting to launch contains applets. If the application was launched, the number of applets that would be booted on the system would exceed the limit (five applets), so the application cannot be launched.
Action
First, reduce the number of applets running on the system by stopping an application running on the system which includes an applet, and then restart the application.
Cannot start this application because system resources (memory, threads, sockets, file descriptors, disk space, or screen size) required to start the application may not be available. <Resources>
Problem
The application cannot be started because the system resources for opening the application may not be available to be allocated.
Action
Restart this application after stopping other applications. It may be able to start this time.
The name listed in the file for the application and the applet name to register with Applet Viewer Service are different. Check the file.
Problem
The application cannot be started because the applet name the application is trying to register in the Applet Viewer Service differs from the applet name included in the application file.
Action
Since it is necessary to make corrections to the application file, contact the application developer.
The following login services cannot be uninstalled:
  - The currently set login service
  - Login services that will be enabled after the device is restarted
  - Default Authentication login services
Problem
The currently set login service, a login service that will be enabled after restarting the machine, and the Default Authentication login service cannot be uninstalled.
Action
Do not uninstall the currently set login service, a login service that will be enabled after restarting the machine, or the Default Authentication login service. To uninstall the currently set login service, uninstall it after restarting the machine.
The file for the application to install does not exist or the file path is incorrect. Try to specify the path again.
Problem
The specified file does not exist or the file path is incorrect.
Action
Specify the file path correctly.
The manifest is not listed in the specified file. Check the file.
Problem
A manifest does not exist for the file specified as the application file.
Action
This application cannot be installed. Contact the application developer.
The file for the license to install does not exist or the file path is incorrect. Try to specify the path again.
Problem
Action
The contents of the file for the application to install are incorrect or information is missing. Check the file.
Problem
Either the content of the files specified as application files is not correct or information is missing.
Action
This application file cannot be installed. Check the file. If there are no problems with the files, contact the application developer or the application support help desk.
The contents of the file for the license to install are incorrect or information is missing. Check the file.
Problem
Either the content of the files specified as license files is not correct or information is missing.
Action
This license file cannot be installed. Check the file. If there are no problems with the files, contact the application developer or the application support help desk.
Cannot install this application because a code signing has not been confirmed to be valid. Get a valid code signing.
Problem 1
Cannot confirm that there is a valid code signature inside the application file.
Action
Perform the correct code signing operation for the application.
Problem 2
The file may have been altered.
Action
Cannot install this license because the specified application and license do not correspond. Try to specify a path for the license file again.
Problem
The application cannot be installed because the specified license file does not correspond to the specified application.
Action
Specify the license file that corresponds to the application.
The specified file is not system application. Check the file.
Problem
The specified file is not system application. It cannot be installed from the [Enhanced System Application Management] page.
Action
Install it from the [Install MEAP Application] page.
Cannot install this license because the number of license file ID logs that can be saved has exceeded the limit. Contact your service representative.
Problem
The license file cannot be installed because the number of license file ID information logs contained in the license file exceeds the number that can be saved.
Action
Contact your local authorized Canon dealer or sales representatives.
Cannot install because a used license file is specified. Try to specify the file again.
Problem
License files that have been installed once cannot be installed again. The specified license file has already been installed.
Action
Since the specified license file cannot be installed, specify another file.
To install the specified application, a license file must be installed at the same time. Specify a license file.
Problem
You cannot install the application unless you specify the license file that corresponds to the application at the same time.
Action
Specify the corresponding license file when specifying the application, and then install them.
The following information in the specified application is incorrect. Check the file. <Inaccurate information>
Problem 1
<Inaccurate information> in the application file cannot be recognized as correct information.
Action
Contact the application developer or the application support help desk.
Problem 2
If the <Inaccurate information> is the MEAP Specifications, the application's MEAP specification values and the printer's MEAP specification values do not match.
Action
The following information is missing in file for the specified application. Check the file. <Missing information>
Problem
The application cannot be installed because required information is not included in the application.
Action
Check the file. If there are no problems with the files, contact the application developer or the application support help desk concerning the <Missing Information>.
The specified application does not support this device.
Problem
Some applications can only be installed in certain printer models. It cannot be installed in this model.
Action
Specify an application that supports this printer.
The specified license does not match this device. Specify an installable license.
Problem
License files contain the serial number information of printers in which the license file can be installed. The specified license cannot be installed because it does not contain the printer's serial number information.
Action
Specify a license file that matches the serial number of this printer.
Cannot install this application because an applet included in the specified application has exceeded the area that can be displayed in the device panel.
Problem
The application cannot be installed because the display area of an applet included in the application exceeds the area that can be displayed on the operation panel of the printer.
Action
Install an application that contains applets that support this printer.
The specified file is an update file. Stop the application that you want update and then install the file.
Problem
The specified application file is a file for updating an application which is already installed. It is necessary to stop the application which is to be updated before updating.
Action
Stop the application that you want to update, and then perform the update again.
The specified file is an update file for a login service that is currently set. Switch to another login service, restart the device, and then install the file.
Problem
Although the specified application file is an update file for the login service that is currently set, it cannot update a login service that has already started.
Action
To install the update file for the login service, start another login service, and then install the update file.
Cannot install this application because storage space has been exceeded. Uninstall other applications and then try to install it again.
Problem
The application cannot be installed because there is not enough free storage capacity.
Action
Make storage capacity available by uninstalling an application that is not being used.
Could not cancel installation. Installation has been successfully completed.
Problem
The [Cancel] button was pressed when the installation operation could not be cancelled.
Action
Disable the license file, download it from the [License Management] page, and then uninstall it.
The process is canceled because the system has been shut down. Restart the system, and then perform the process again.
Problem
The installation could not be completed because it conflicted with a system shutdown.
Action
Restart the printer and perform the install again.
Cannot install the application or license because another application is being installed, or the firmware being updated. Please wait a moment and then try again.
Problem
Either it is installed in another application outside of SMS, or the application cannot be installed because the firmware has been updated.
Action
Wait until the processing stops before installing the application.
Error: <Error Details>
Problem
An error has occurred for some reason. See <Error Details> for details.
Action
If the solutions given in <Error Details> are unclear, contact your local authorized Canon dealer or sales representatives.
051R-0HS
