» MEAP » List of Error Messages (MEAP) » Errors Relating to the [Authentication Information Settings] Page
Settings are incorrect.
Check to see if the password is incorrect.
Enter Dept. ID within 7 digits.
Check to see if the Department. ID is registered with the device.
Problem
Cannot set authentication information because either the Dept. ID entered does not exist, or the PIN was entered incorrectly.
Action
Enter a Dept. ID and PIN that are registered in the printer.
The [Department ID] is incorrect.
Enter an integer for the [Department ID].
Problem
The Dept. ID that was entered is a positive integer, but the registered Dept. ID is not a positive integer.
Action
Enter the correct Dept. ID that is registered in the device.
The [Department ID] is not entered.
Problem
The Dept. ID is blank.
Action
Specify a Dept. ID.
Could not set authentication information because an error occurred.
Problem
An error has occurred for some reason, so authentication information could not be set.
Action
Contact your local authorized Canon dealer or sales representatives.
Could not delete authentication information because an error occurred.
Problem
An error has occurred for some reason, so authentication information could not be deleted.
Action
051R-0HL
