» MEAP » List of Error Messages (MEAP) » Errors Relating to the [MEAP Application Management] Page
Cannot start this application because there is no distributable software in the application. Get a distributable software.
Problem
The application cannot be started because it does not contain any redistributable modules.
Action
Contact the application developer.
Cannot start this application because the number of bootable applets has exceeded the limit. Start this application after stopping other applications.
Problem
The application that you are attempting to launch contains applets. If the application was launched, the number of applets that would be booted on the system would exceed the limit (five applets), so the application cannot be launched.
Action
First, reduce the number of applets running on the system by stopping an application running on the system which includes an applet, and then restart the application.
A license is needed to start this application. Try to start it again after installing a license.
Problem
Cannot start the application because a license file is not installed.
Action
Install the license file, and then restart the application.
Cannot start this application because system resources (memory, threads, sockets, file descriptors, disk space, or screen size) required to start the application may not be available. <Resources>
Problem
The application cannot be started because the system resources for opening the application may not be available to be allocated.
Action
Restart this application after stopping other applications. It may be able to start this time.
Cannot uninstall this application because the license file has not been deleted. Uninstall the application after deleting the license in the [License Management] page.
Problem
The application cannot be uninstalled because the license file for the application still exists inside the printer.
Action
Uninstall the application after deleting the license on the [License Management] page.
The name listed in the file for the application and the applet name to register with Applet Viewer Service are different. Check the file.
Problem
The application cannot be started because the applet name the application is trying to register in the Applet Viewer Service differs from the applet name included in the application file.
Action
Since it is necessary to make corrections to the application file, contact the application developer.
Error: <Error Details>
Problem
An error has occurred for some reason. See <Error Details> for details.
Action
If the solutions given in <Error Details> are unclear, contact your local authorized Canon dealer or sales representatives.
051R-0HJ
